Bigger(lower hanging) Air Damn
Old Jun 10, 2004 | 01:38 PM
94zLT1's Avatar
i know there was a guy on here that bought a bigger (lower hanging) air damn to scoop more air into the radiator..i know it works wonders and i want one and forget what place is selling it...any help?
Old Jun 10, 2004 | 02:59 PM
Z28SORR's Avatar
Wings West sells them. They normally are part of the FX kit, but can be purchased seperately.
Sorry, don't have the linky.
Old Jun 10, 2004 | 03:23 PM
OldSStroker's Avatar
Re: Bigger(lower hanging) Air Damn
A larger/lower air dam prevents more air from geting under the car which causes a low pressure area behind the dam (and the radiator) so the air is really sucked thru the radiator rather than "scooped" into it. It generally helps reduce total vehicle drag and can help reduce rear end lift at speed. Done properly, the reduced drag can improve fuel economy. Pretty close to a "free lunch"!
Removing or shortening the stock air dam has just the opposite effects which are mostly all bad.
Old Jun 15, 2004 | 09:19 PM
arnie's Avatar
I believe this applies to most of those mini air dams under many vehicles on the road today. Rather than help direct air up and in front of radiator, helps lower pressure behind radiator, which, as OldSStroker stated, helps pull air through radiator. This by generating a larger pressure differential between area in front, in comparison to area at the rear of radiator.
Without means to identify the path, of the airstream, over, around, and under a vehicle, it's tough to 'visualize' how that invisible medium is reacting to a given body shape, as it 'plows' through the mass of air. What may seem logical, is really not the case.
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
HectorM52
Jan 31, 2015 07:29 PM
95chwagon
Jan 13, 2015 09:19 PM
Britbilly
Jan 7, 2015 08:49 PM
