Heistation/stumble solved
Old Jun 13, 2004 | 01:36 PM
z28importkilla's Avatar
i've had hesitation for about 6 months now. I've changed the plugs, wires, coil, icm, mass air meter, iac...basically everything except for the optispark. It hesiatated in the whole rpm range bad and would do it worse when it got hot. I recently needed to put in a new clutch so i bought a Ram Stage 3 clutch and had the guy put it in today. I told him i was leaking a bit of oil and thought it was the rear main seal so i told him to take a look at it while he was down there. I went to go pick up my car just now and i asked him if it was the rear main seal that was leaking. He told me when he had the tranny and clutch out he could see that the oil was leaking from the back of my intake and onto my wires, therefore oil soaking my wires. He said that was causing my hesitation. He also told me it was kinda of a big project and something that he doesnt really want to get into....my question is how much is it to have someone repair the oil leak and pull the intake? Am i looking at an Arm and a leg?
Old Jun 13, 2004 | 01:45 PM
scoobysnax83's Avatar
its really not that difficult and if you do it yourself should cost you no more than $30... Afternoon job at most. Do some searches
Edit:One thing that I do have to say is that unless the front is leaking which is abnormal (or less likely I should say) there is slim to no chance of getting oil on the wires or any ignition related system. I would be more worried about toasting that new clutch you just put on
Old Jun 13, 2004 | 01:53 PM
he said my wires were covered in oil? so do you think that isn't causing my hesitation?
Old Jun 13, 2004 | 01:54 PM
well if they were covered with oil then it probably soaked in and is causing missfires. If you have soaked wires then you more than likely have bad valve cover gaskets...
Old Jun 13, 2004 | 02:07 PM
so should i change the valve cover gaskets or intake gaskets? are there any websites that show how to do this?
Old Jun 13, 2004 | 02:09 PM
you need to figure out where the oil is coming from. Run your finger around the edges of the valve cover gaskets and behind the intake. Gunk is fine, but liquid oil is not...
ZXXVIII
Sep 1, 2015 10:13 PM
TGGodfrey
Aug 17, 2015 08:43 PM
big dave
Mar 23, 2003 11:28 AM
Maine_LT1
Mar 18, 2003 09:01 AM
Who5252
Feb 4, 2003 09:18 PM
