ses light, dtc p0125, any suggestions?
Old Jun 11, 2004 | 05:01 PM
Camaro97USAF's Avatar
It did this when my car started bucking a bit, and wouldn't idle unless I floored it . anyone have any info?
Old Jun 11, 2004 | 05:09 PM
oh yeah, have a 160* thermostat, just replaced the water pump a few months ago, and put in a new coolant temp sensor, since I broke the old one. Coolant levels fine.
Old Jun 11, 2004 | 10:58 PM
HBHRacing's Avatar
are your fans on too soon? also could be a bad 02 holding you in open loop too long
Old Jun 12, 2004 | 04:10 PM
no it actually seems like the fans are coming on late. or normal, the temp gauge is at the line before it goes red before it starts to cool down, unless I have my defroster on...
Old Jun 12, 2004 | 04:14 PM
stereomandan's Avatar
P0125 - Engine Coolant Temperature (ECT) excessive time to closed loop
You probably already know that, but sounds like maybe the wiring/ECT didn't quite get hooked up right.
It would seem that you would get other codes if everything was being held in closed loop. Sounds like it's just your ECT.
You did bleed the air out of your coolant lines right? Make sure the engine is good and hot and bleed the air out of both bleeder screws with the engine running.
Dan
Gtpguy
Jan 26, 2015 04:50 PM
squarehead
Jan 15, 2015 07:02 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
