How do you check for a collapsed lifter? (comp r's)
Old Jun 10, 2004 | 06:10 AM
96LT1TX's Avatar
basically what it says in the title, I am about to take the heads off, and want to check the lifters to make sure that wasnt my problem... any ideas?
Old Jun 10, 2004 | 08:34 AM
bunker's Avatar
run up the engine with valve covers up just at idle for about 10 seconds, shut the car off & immidiately take all the rockers off, then push on the pushrods with your hand, a badly collapsed lifter (when they collapse they ussually show this way) you'll be able to push down on the lifter, as in it'll go in, if they are fine then the pushrod won't budge.
Also, another way is to have someone in the car, crank the starter & let off with valve covers off & fuel injector fuses out, stop cranking after about 1 second & look at all the springs that are compressed, watch them for about 20 seconds, see if there is one rocker that going up faster then the rest.
Easiest way that sometimes tells you is take fuel fuses out & keep cranking, if you have an irregular speed up or slow down while cranking that means you either have a collapsed/stuck lifter or a bent valve.
Old Jun 10, 2004 | 03:31 PM
96LT1TX's Avatar
hmmm is there any way to tell w/ the lifter in your hand? I already have the valvecovers off, I bent a valve and am pulling the heads anyways... if the car has been cold for a while can I still try the push on the pushrod thing?
will it go down or does it have to be warm ??
thanks
Old Jun 10, 2004 | 06:23 PM
Spinner's Avatar
thanks
They need to be pumped full of oil
Old Jun 14, 2004 | 07:56 PM
96LT1TX's Avatar
anyone got an idea of how to check for a collapsed lifter w/ the lifters out of the car?
thanks
MadMav
May 25, 2015 09:35 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
