Am I missing my pcv valve???
Old Jun 9, 2004 | 07:04 PM
Getsome17's Avatar
Just aftter getting home, I noticed a burning oil smell. I opened the hood and it looked like it was comming out where the pcv valve sits on the valve cover. So I thought my pcv valve was stuck and I needed a new one. So I pulled off the plastic elbow and all there was was the rubber seal on the valve cover. So i took that off too, and there was nothing there. Am I missing somthing??? Or has my car been running without a pcv valve since i bought it???
Old Jun 9, 2004 | 07:08 PM
mojo's Avatar
On my 94,the PCV valve is on the drivers side intake about midway.
Old Jun 9, 2004 | 07:53 PM
n2ceptor's Avatar
PCV is located on the driver's side on the intake just behind the thottle body.... If you check Shoebox's homepage, I believe there is a pic.....
Old Jun 28, 2004 | 04:12 PM
IndyZman's Avatar
Re: Am I missing my pcv valve???
The thingy you unplugged from the passenger side valve cover is just a hollow elbow connector that is just some emission control venter "i believe". Too bad it isn't the actual location for the PCV valve; because, it would make it so much more easier to replace. The real location on my 97 is situated in a knuckle scaping location under many clusters of tubes, wires, brackets on the driver's side. I'm changing mine in a while and am not relishing the idea of departing with all the skin of my knuckles on my right hand.
Old Jun 28, 2004 | 05:56 PM
Mtrhds94Z's Avatar
The elbow and line on passenger side from the TB is the INTAKE side for air into the PCV system.. [air goes from TB to valve cover into engine then PCV [on drivers side] evacuates it...
Old Jun 28, 2004 | 11:29 PM
Getsome17's Avatar
Thanks I found my problem was the oil was leaking out the dipstick tube
HectorM52
Jul 30, 2017 11:46 AM
lt1matt
Mar 21, 2015 07:35 PM
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
