coolant crossover lines plugged in the back of heads?
Old Jun 9, 2004 | 12:06 PM
reuter's Avatar
i recently purchased a set of ported heads and the cooant crossover linein the back was plugged with a pipe plug (metal threaded plug). do i need to remove these and run the crossover line or should i delete the crossover line altogether?
these are stock LT1 castings
Old Jun 9, 2004 | 12:33 PM
TN94Z's Avatar
I'm pretty sure that deleting the tube is not good. From what I have heard and read, that is an important part of the reverse flow cooling system.
Old Jun 9, 2004 | 01:12 PM
CamaroBoy96Z28's Avatar
That tube is an important part of the system, you can't run without it.
calaban
May 18, 2020 06:43 PM
HectorM52
Jul 30, 2017 11:46 AM
Sandersen511
Jan 13, 2015 03:49 PM
Jazsun
Dec 29, 2014 12:14 PM
