HVAC check valve cracked
Old Jun 10, 2004 | 07:21 PM
n2ceptor's Avatar
I am on my second check valve... They are cracking on the side..... Any ideas on why this is happening??... Its located at the normal spot , not by anything hot...
Old Jun 10, 2004 | 07:45 PM
DonHood's Avatar
Eh, I just bought a $1.88 vacuum hose "T" connector and used that in place of the check valve.
Old Jun 10, 2004 | 07:52 PM
n2ceptor's Avatar
I thought about that, but figured the check valve must serve a purpose...
Old Jun 10, 2004 | 08:09 PM
DonHood's Avatar
That's sorta why I posted it, to see if anyone would mention any probs with it.
Haven't had any probs thus far though.
Old Jun 10, 2004 | 08:39 PM
It just won't hold any vacuum during low vacuum situations and when the engine is off.
Old Jun 10, 2004 | 09:00 PM
DonHood's Avatar
Thanks, I was hoping you'd chime in. Does this mean that my vacuum canister is pretty much not used, and it's just going off of manifold vacuum?
Old Jun 10, 2004 | 09:10 PM
n2ceptor's Avatar
So, at WOT the doors will close???? I could live with that.. But I still dont know why the valve is cracking??? Clogged line???
It works fine for acouple of days then, crack...
Old Jun 10, 2004 | 09:40 PM
Basically, yes. It does not get a chance to store any vacuum.
Yeah, the air direction will change to the floor and defrost during low vacuum. Other people have reported that problem (repeated cracking). I don't have a good answer for it.
Old Jun 10, 2004 | 09:55 PM
n2ceptor's Avatar
Thanks, Rob...
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
