stock crank pulley
Old Jun 9, 2004 | 10:24 PM
flusz28's Avatar
Exclamation stock crank pulley
How do i take off the stock crank pulley so i can install the vortech crank??
Old Jun 9, 2004 | 10:32 PM
Smoke T/A's Avatar
First take out the 3x 5/8ths bolts and then hook a 3 jaw puller up to it and yank it off. Some times you can get off with your hands and dont need the puller. HTH
Old Jun 9, 2004 | 10:34 PM
flusz28's Avatar
having a hell of a time getting those three bolts off - since i have no way to stop the pulling for turning.
Old Jun 9, 2004 | 10:48 PM
Smoke T/A's Avatar
Auto or m6? I would assume auto since if it is a 6-speed you can just put it in gear. Take off the converter dust cover and stick a screwdriver through the flexplate.
Old Jun 9, 2004 | 10:52 PM
flusz28's Avatar
okay will give that a try- thanks
Old Jun 10, 2004 | 12:23 AM
ArizonaZ's Avatar
Also leave the belt on while you do it...That will hold it in place a little more.
Old Jun 10, 2004 | 02:50 AM
94Z28WP's Avatar
I used a skinny craftsman prybar and slipped it through one of the pulley openings and rested it firmly against the block... I could break lose the three bolts then.
Old Jun 10, 2004 | 08:20 AM
flusz28's Avatar
Belt and other things were already off - thanks guys yeah i will have to find something to pry up against my pushing on the crank.
Old Jun 10, 2004 | 09:30 AM
cmking26's Avatar
If you have everything off just use an impact wrench, it will zip em off real quick and not spin pulley.
Old Jun 10, 2004 | 10:12 AM
flusz28's Avatar
no air tools one day
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Noer
Feb 28, 2015 11:29 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
