can i remove the guide plates and just run self alligning rockers
i bought afr heads and i wanted to reuse my basically new comp 1.6 rockers. there shouldnt be a problem as long as i find hardened washers to put in place of the plate? where do i find the washers and can i use these rr's without a problem.
dave you are correct but when i talked to an engine builder he tried to get me the washers and couldnt, which i found weird. I tried to call AFR but couldnt get through. SO i wont run into a problem if i get washers and keep SA rockers?
THANKS
THANKS
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
