new cam installed
Old Jun 11, 2004 | 02:03 PM
fearnside5's Avatar
new cam installed
What should the car idle at in drive? Stock tuning is 550 rpm but, seems too low . The cam specs are as follows: Crower #00402LM hyd. roller - intake duration 278 lift .498
exhaust duration 286 lift .519
lobe seperation 114
duration at .050 intake 220 exhaust 228
lobe lift intake .332 exhaust .346
Engine is 95 LT1 355 , stock aluminum heads with valve job manley valves 2.00 intake 1.550 exhaust - Everything else is stock. Trans. is automatic
Old Jun 11, 2004 | 03:18 PM
madwolf's Avatar
You need tuning done for it to idle OK. 550 is too low. I'd recommend at least 750 RPM for in gear idle. 800 RPM would probably be better though.
Stock is 550/650 for gear/neutral.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
