Code 82
Old Jun 10, 2004 | 07:56 PM
Andrew04ME's Avatar
Code 82
Solenoid A Fault. This is the code Freescan retrieved for me. I think this is the reason i only have 2-3 gears. I believe the replacement part # is 12538778, someone correct me if im wrong. Has anyone replaced this before? Would it just necessitate removing the console around the shifter?
Thanks,
Andrew
Old Jun 11, 2004 | 05:19 AM
slopokrodrigez's Avatar
Check the #11 fuse under the hood (10amp). If that's ok, cycle the solenoid with the scanner and listen for it to click. If none of that does anything, pull the tranny connector and check +12V on the pink wire and when the solenoid is engaged, check for ground on the light green wire.
Old Jun 11, 2004 | 07:52 AM
The solenoid is inside the transmission, not in the console. Remove the transmission pan for access.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
