Jet-Hot slip fit Leak
Old Jun 11, 2004 | 03:28 PM
1994CamaroZ28's Avatar
Please excuse me for making the post yes i do know how to use the search function
alot of people bought some jet-hots lately,
i got tthem installed no problem but i do beileve its the slip fit tube leaking
i hear a very constant tick speeds up with rpm slows down at lower rpm, pluis when im running down the road much past like 2k rpm you can actually hear a extremly loud popping sound.
is this the symptoms you guys had or different?
Also i have one of two options a muffler shop in town will make me a Y for 175 or i could buy one off the net what you guys recommend
thanks for reading my post im sure the information will help more then just me.
Old Jun 11, 2004 | 03:43 PM
Red96Lt1's Avatar
I got a hooker Y pipe, it's $200. I got mine from Jet Hot coated for $250.
Old Jun 11, 2004 | 11:22 PM
any good news on mufflex what about the slip fit problem and noise no responces?
Old Jun 11, 2004 | 11:58 PM
SiDeWaYZz28's Avatar
well im thinkin u can probally use jb weld...has anybody done that??is that a bad idea???
Old Jun 12, 2004 | 12:24 AM
IrocSS85's Avatar
I smeared hot permatex on the inner pipe before I installed it and used a tclamp. I know summit sells the clamps. it fits 1 3/4" tube. it gets very tight w/out crimping the pipe at all. no leaks yet, but havent put many mi.s on it at all yet.
jb weld might work, but if it does work, it may not come apart again. not good if you plan on removing it ever.
Keenan
Jan 19, 2023 12:24 PM
mschmidt33
Mar 15, 2015 07:20 PM
jackpawt883
Feb 26, 2015 09:04 PM
CARiD
Jan 27, 2015 06:27 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
