Could this be caused from a optispark?????
I have a 94 camaro z28. When my car gets hot my car seems to be missing like - it tends to struggle to build up rpms like it's missing. Could my opti spark be going. Are those signs. How can I check to see if my optispark is bad
Re: Could this be caused from a optispark?????
re:
My car is doing the same thing it idles great but when I actually get into the car has no performance. When I had my cam installed the lt4 hot cam. The guy had installed a USED opti spark he bought it for $150.00. I guess he said my old one was bad which I had that replaced last summer which also was a used one. I'm guessing it's the opti. THE dealership should tell me right???
Re: Re: Could this be caused from a optispark?????
Originally posted by transamtom
Sounds like the ignition module,its located above the coil on the front of the drivers side cylinder head
oh and personaly I would NEVER buy a used opti. for my car. You could of spent $60 more and got one from Jason Cromer.
Things I would check:
-plugs and wires look for fireworks at night
-fuel under load also
-check warning lights if u have um probably don't though I didn't
anyways
-vacuum leaks
-check your cat
I guess someone else can chime in with more. Or do a search the wealth of knowledge on this website for are cars is amazing.
anyways
-vacuum leaks
-check your cat
Formula Steve
Sep 19, 2023 08:31 AM
jackpawt883
Sep 10, 2015 08:53 PM
