93 z28 owners
Old Jun 13, 2004 | 02:07 PM
DonutMachine's Avatar
93 z28 owners
i have a 93 camaro z with 2.73 and I changed my gears to 3.23 which sensor for my tranny do i need? I need for someone to read their p/n off of a 3.23 car basically cause the dealer's around here seems to not know what i'm talking about and can't order the part. 4L60 is non electronic. thanks
Old Jun 13, 2004 | 03:02 PM
Dave89IROC's Avatar
I think the 93 still used gears on the VSS to adjust for tire size/gear ratio?
Old Jun 13, 2004 | 03:34 PM
Fastbird93's Avatar
You have to change the "drive" and "driven" gears in the tranny. Sorry, I don't have a part # for your setup though. You could probably call a dealership and ask for a part number on them.
Old Jun 13, 2004 | 03:35 PM
street demon2k3's Avatar
cant really help you out w/ that one but check out the speeddensity.org(something like that). they can help you out its a 93 specific forum. ive been there a few times and they helped me out a lot.
Old Jun 13, 2004 | 08:44 PM
the dealer's out here are dumb *****, they can't tell me which sensor is for the 3.23 car cause they don't know
i'm going to e-mail detroit to get to the bottom of this.
Old Jun 13, 2004 | 09:05 PM
neil350's Avatar
Like said before, you need to change the gears, no sensor.
Old Jun 13, 2004 | 09:39 PM
agent z28's Avatar
You need to change the speedometer gears. There is no sensor that you can reprogram. Try contacting Lingenfelter, they offer recalibration gears for most rear end ratios.
Old Jun 14, 2004 | 01:54 AM
Bralgar's Avatar
What's this talk of gears? My 93 has electronic sensor speedo for the tranny, no cable.
Pretty sure anyway
Edit: I just crawled under my car with a flashlight (yes at 2am here) and I did not see any #'s on my sensor. BUT, I guess it does look like it could be a gear driven sensor
Old Jun 14, 2004 | 02:02 PM
93 4L60 has a drive and driven gear behind the speed sensor, 94 and up has a electronic speed sensor with two magnetic strips on it.
Old Jun 14, 2004 | 02:06 PM
better yet does anyone have the option code for 3.23 gears in the 93 z28. D8A, D8B, D8M, D8I or D8N?
Old Jun 14, 2004 | 04:03 PM
Thanks guys, but I found it.
The part number is
10456089 for the 3.23 car/ D8I
10456088 for the 2.73 car/ D8?
Old Jun 14, 2004 | 04:21 PM
INFERNO's Avatar
if you still didn't order them and if they are expensive let me know becuase I have a couple left over from the A4-M6 conversion that I will just mail to you. Just email me at z1bad93z@hotmail.com
Old Jun 16, 2004 | 01:37 AM
WhoomWhaatWhaah's Avatar
I found them at www.acdelco.com the easy way to tell 2.73 is black and the 3.23 is white
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CamaroHeed
Mar 18, 2020 09:50 PM
cmdeshon
Jan 4, 2015 11:15 AM
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
