Felpro gaskets at Discount Auto? Are they .039's?
Old Jun 11, 2004 | 01:02 PM
ZDriver96's Avatar
Im fairly sure felpro only makes .039 thick replacement gaskets for our Camaro z28s. The guy at discount didnt know the specs on it.
impala = .029
felpro = .039
stock = .051
right?
Just want to make sure i got the .039 thick gaskets. Not sure which is the part number on here.. there are lots of numbers.. if anyone knows the .039 thick gasket number could u post it? thanks.
Old Jun 11, 2004 | 01:24 PM
xxsaint69x's Avatar
felpro 1074?
btw what are "440hp LE Heads"?
Old Jun 11, 2004 | 01:28 PM
ZDriver96's Avatar
These say
Gm products V8
350 (5.7L) Engine 1992-1996
Replaces No. 12551488
9966PT
10094
020628
Old Jun 11, 2004 | 03:04 PM
xxsaint69x's Avatar
i dont know man..just order Felpro 1074 if you want .039 gasket.
Marcin
Old Jun 11, 2004 | 03:07 PM
ZDriver96's Avatar
I called up Fel Pro.. The ones I have are .049 thick and are not 1074's..
THe guy on the phone tried telling me that .039 thick gaskets on a 11.3:1 engine will cause it to detonate on pump gas 93.
I dont think so.. Im going with .039 felpros. He must be confused or unaware of reverse cooling, aluminum heads and better quench for atomization of fuel..
Old Jun 11, 2004 | 05:21 PM
amean94ta's Avatar
just some info 9966pt are stock replacment( dont go over 11:1 the 1074 are .031 thick i use the 1074 on my 13.6:1 396 lt1 and they work good for na applications if using n20 you need cometic and they run $65 ea
Old Jun 11, 2004 | 05:32 PM
xxsaint69x's Avatar
1074 is not .031 its .039. And no you dont need cometic gaskets to run n2o
Old Jun 12, 2004 | 08:51 PM
amean94ta's Avatar
the ones i got are .031 and you cant use n20 with the 1074 if you dont belive me call felpro and ask them
Midnight_Z
Feb 16, 2016 09:36 PM
4586
Apr 29, 2015 01:43 PM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
