optispark help
Old Jun 13, 2004 | 11:51 AM
mark_maroz28's Avatar
optispark help
Friend is doing optispark install he needs to know the number one pin postion on the optispark hope u guys can help cause i dont know what the hell hes talking about . thanks
Old Jun 13, 2004 | 11:58 AM
RamAir95TA's Avatar
Re: optispark help
He should not have a problem putting the optispark back on, since it can only (correctly) go back on one way. What year car does he have? You also will not need to know what piston is at TDC, but if he still wants to know, there are TDC indicators for cylinders #1 and #6 stamped on the back of the optispark. The slot for the pin/keyway, depending on year, will point to the corresponding piston.
What year is his car?
Old Jun 13, 2004 | 12:04 PM
94
Old Jun 13, 2004 | 12:05 PM
RamAir95TA's Avatar
94
http://shbox.com/1/93-94_opti.jpg
Show him that.
Thanks Rob.
Old Jun 13, 2004 | 12:18 PM
Just find the "keyed" slot on the splined drive of the opti and match it up. That's all you have to do. You don't need to know where the cylinder positions are.
Old Jun 13, 2004 | 12:28 PM
the boy is getting on my nerves he says where should the rotor be postioned on the cap when the #1 postion is top dead center i hope hes wording the problem right to me thanks
Old Jun 13, 2004 | 02:39 PM
ttt
Old Jun 13, 2004 | 07:28 PM
Tell him to forget all that and do it like we said. It's not like an old SBC rear mount distributor.
Old Jun 14, 2004 | 12:30 AM
do anyone think he might have perchased a 95 opti instead of a 94
Old Jun 14, 2004 | 01:40 AM
disco192's Avatar
95 opti will have 2 vent holes on the bottom.
One goes to the manifold and one goes to the elbow.
Old Jun 14, 2004 | 08:40 AM
If he did, it won't work. You already saw the pic of the back of a 93-94 above. A 95-97 looks like this. He would not even be able to get the drive portion through the hole in the timing cover.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
