View Full Version : LT1 Based Engine Tech
- glaze on windshield
- Who sells the LS1 Brake setup?
- Tranny Problem
- LT1 Edit on basically stock LT1
- If I were to stumble across $8000-$9000
- true duals?
- What tuneup items for new used Z?
- Intermittant electrical problem
- To replace rack and pinion or not to replace...
- donkey dong
- ***Do I need to modify valve covers for 1.6 rr?***
- ??? for Spohn torque arm users
- Everyone with SPEC problems in here!
- DIY: Gear swap?? Did you do it yourself??
- Cam Shaft Swap
- Torque specs again...
- What's this clunking noise?
- Finally took a look at the opti and got some measurements.
- Dyno Results & A/F Ratio
- help wanted!!!
- 1 burnt plug wire, do I have to buy whole set?
- MAC muffler baffle loose...anyone else have same problems?
- Thoughts on my Hooker Cat-back
- Dyno results are in!!!
- looking for new rims or a place to chrome mine
- Time to rebuild the T-56
- engine swap
- Mac Offroad Pipe???
- 4L60E shifting
- maf smaller then slp cai????
- Quick injector question..
- Crank Hub Help Needed!
- Shoebox, here is the update to the IAC problem...wanna take a look
- 94+ intake on a 93
- EGR valve question ASAP
- Why does my RPM climb to 1700 when i start it????
- hot cam kit with stock 1.5rr?
- CSI/Meziere Elec Waterpump and Timing Chain ??
- Power stumble after restarting????
- will these polylocks work with gmpp 1.6 RRs?
- cutout worth it with a slp 2otl exhaust?>>>
- TPIS cold air intake?
- Hard start problem! HELP!
- Oh Shi! I dont think that was suppost to happen!!
- cant spin the tires? 94 z
- Opti Help For Putting Back On Block
- Hypertech 96 and 97 the same?
- paint job on my t/a?
- X or H pipe for Hooker LT's
- tips for buying used lt1
- coolant leak?
- Tazzo VPC?
- just installed slp cai 1 prob!!!!
- Headers or Exhaust
- Need an Odd Part Number
- What would you do first
- I need to know a little about the 1997 Camaro SS
- Bodywork help needed: door rubbing
- Help how do you remove the sensor off the injector
- sound question - gut cat/high flow cat
- Spark Plug Wires (type)
- Are the Borg Warner and Tremec trannies different?????
- part number for knock module
- Used LT1 Heads
- Need a part # for TA dash LT1
- What kind of power difference?
- How to stop heater hoses from leaking coolant?
- just installed manual fan switch
- will 17x11s fit
- what is a floating valve?
- Heads cam manifold etc.
- can this be done
- Polly Locks?
- need help clearing up minor issues on older 700R4 into a 93 Camaro...
- where to get rims
- Well, I think I need new injectors (XE 224/230 112 LSA)
- cam/chip question
- Need fast response to flexplate question
- Now i am mad
- Few spark retard questions
- Fuel Filter change questions?
- Brakes on 95-z
- SES Light Help
- Anybody know where to find aircraft switches?
- Flowmaster VS. Hooker cat back.....
- Dual exhaust with cut-outs?
- been adjusting RR's, but everytime lash comes back
- How to go Faster?
- Changing fuel pump. Need How To
- ANy tips on replacing the pinion seal?
- Getting the intake right the first time...
- Will I exceeded 100% injector duty cycle??
- How often do you change your....
- Help on Choosing a POSI
- Q re: short stick noise fix
- i have cam installed, but i have no tuning for it.
- Plug related (I've searched) Quick! :-)
- ABS light comes on under acceleration
- Whats the average HP?
- SLP headers and EGR tube
- Cam + Emmisions
- Does everyone's car actually shift where you have it set to shift at?
- Help! Had car towed today!
- Xe 230/236
- anyone have one of these grilles?
- any estimates on price??
- Can anyone recomend place to get subframe connectors welded in in SC?
- Stock Stift Points
- SS airbox foam
- What to do next?
- I'm a moron! (transmition related)
- vibrations above ~4k RPM
- Car doesn't like to start after it rains
- Borla Y-Pipe 93-95 LT1 w/stock manifolds, WORTH IT?
- sfc install paint
- SVO 30 lbs injectors
- Tranny Problems
- how to hook up a shift light??
- Order of operations...
- Electronic Cut-Outs Pro/Cons of Brands
- One last dowel pin grinding question...
- Pics of hidden shiftlight install w/in
- Roller Rocker Questions Inside, someone please chime in!
- m6 having some difficulties
- Peeps w/ the 6spd conversion..How long did it take you???
- best factory parts?
- LT1 camaro Vs LS1 camaro (steering wheel) airbag
- Simple intake question...
- Difference in Dextron III Trans Fluid?
- 93 Z-28 fuel level gauge
- AC on during defrost???
- Air foil question? just got it as a b-day gift
- how can you tell if your rear is bent?
- Jacking from the rear
- Typical range of oil temperature
- Magnaflow slashed or round...need feedback
- hooker catback
- Where do stcok heads make no more flow? At what lift?
- Got my electric cutout!
- Where to buy parts for making ORP?
- EGT Guage readings...Whats normal..
- Heads/cam might be fixed!!!
- Advice of changing parking lamp/turn signal bulb
- 15x10" draglites with 26x12.5-15 M/T
- 58mm z06 maf
- Rebuilding did not Help Tranny!!
- P1416 is back but 0410 is with it
- lt1 4 bolt vette block?
- Comp XE 224-230
- I heard this is great
- Are ram clutches any good?
- need help
- tranny
- sprayed lube now security light is on HELP??????
- help needed!!!!
- JET fan switch
- Strange smell after TB bypass and exhaust
- bumpstop
- Anyone know how many knock sensors a '95 Formula has?
- Please help..Brake question(I dont wanna die)
- What STR are you running?
- car wont start when it's hot?
- What does this pulley drive?
- SES - P1361 Help!
- cam question which one to go with
- What is the part # for cloyes true double timing chain?
- Torque spec for oil pressure sending unit fitting?
- Engine builders piston to valve clearance HELP..
- before i change my fuel pump....
- Just got a Vig. got a few questions..Vig. Users inside...
- failed emissions - help
- part number question
- ball park figure
- What size injectors should I use for my 383?
- ***Need help with timing chain***
- part numbers
- A question about 3.73:1
- valve spring instal question?
- more oil leaks rear main?
- trans temp ?
- 383/396 owners...how does your combo run?
- Noob question, stall speed?
- Any aftermarket parts available for 96 chevy caprice?
- adjusting valves with bigger than stock cam?
- are my leather seats screwed
- autozone (melling) pushrods hardened?
- Spark Goru's
- ? about stock heads on a 97z
- Engine builders need help w\ piston to valve clearance
- +1, +2, +3, +4 ?????????
- rear end gear switch
- 95 Z28 help needed
- Part# for MSD wire change?
- 93 rear end on 94, ok???
- Jet Hot Cleaning?????
- some opinions
- 94 auto. speed limiter and 110 mph speedo - BOO!!
- please help!!!
- Appearance Question
- Price of stock clutch set up
- Is this clutch ok?
- AC question
- got new clutch ,but no instructions
- A/C compressor
- What size injectors for 383?
- I only need a 400 balancer and my stock flexplate for 383 balance right?
- where can I get my TC
- Switchign from D to N while driving.
- no rev-limiter?
- Ok this is my problem... PLEASE tell me its the solenoid...
- Which 230/236 cam for a 383?
- Anyone know the part number or the correct part for the rear main sea?
- What stall?
- DANGEROUS? i think its the wheel bearing...
- Folks with roller rockers, inside please...
- Cam install
- LT4 gaskets reusable?
- MAF screens???
- How does someone do a compression check on their car?
- Grinding down dowel pin.
- Oil Cooler???
- New Corsa tip design!
- Top end cutting out
- How much of an increase with a valve job??
- What happened when your opti died?
- What sort of power should I make?
- looking for sun visor's without mirrors?
- broken rocker arm stud
- PN for coolant temp sensor
- how hard to take off Heads??
- Is the J 37043 Parking Brake Cable Release Tool
- HELP. Loud banging and bad vibration this morning
- Help me hit 12s please...
- Tranny/Clutch Problems
- auto to six-speed
- i'm confused, suspension alignment q's
- Tuning
- Stopping SLP Shorty header leak
- Friend just asked to go legally road race
- Part #'s for coil and header gaskets
- Oil Pressure
- Light show under hood
- Are all Chevy 4L60E interchangeable???
- 4L60E taking a dump??
- What a day
- Oil PSI
- 93 Z28 Headers
- Funny Rev When you stomp on it
- t56 changeover
- Gasoline smell at startup??
