X or H pipe for Hooker LT's
Old May 1, 2003 | 06:15 PM
97WRAITH's Avatar
Anyone know where I could buy one and which is better for power that is?
Thanks!
Old May 1, 2003 | 07:35 PM
93_Z28_6spd's Avatar
I made a custom h pipe setup when I put on my Dynatech long tube headers. It was from flowmaster 3" h pipe balance system its like 45-50 bucks. have to weld it up to your system, I ran it since I did duals... You could do the same, I belive sumittracing sells one system with their name on it for a few dollars less. Hope that helps. But if you run h or x pipe you will loose some ground clearance.
Old May 2, 2003 | 12:00 AM
1982z28with18s's Avatar
TTT...Good topic. I am planning on doing a H-pipe, only cuz it's a lot cheaper, and won't take as much ground clearance. I am getting it custom made for $140, which includes parts and labor, minus the bullet mufflers.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
