JET fan switch
Yes, I use this set up on the TA and it seems to work just fine. But I hooked it up a little different from what the instructions say. It requires to be install in the passenger side cyl. head but it's very hard to get to. So instead I install it on the coolant return line from the back of the cyl. head which took only 10 min. to install.
There is another way doing it cheaper with just wiring up the fan relay wires, which i dont know to well. Maybe some will point you to that directions.
Vinny
Vinny
carguyshu
Jan 22, 2017 11:19 AM
chesee48
Aug 22, 2002 08:28 AM
BLACK Z !
Sep 25, 2001 11:37 AM
BLACK Z !
9
Aug 11, 2001 05:46 AM
