Polly Locks?
Old May 1, 2003 | 03:24 PM
Wildwill532's Avatar
Polly Locks?
Do you have to buy these when you install new rocker arms and springs?
Old May 1, 2003 | 03:52 PM
rocmemphis's Avatar
You don't have to have them but they are nice. Generally help the rockers to not come loose.
Old May 1, 2003 | 05:03 PM
trax's Avatar
AFAIK you need poly locks with Comp Pro Magnum RR's. Just make sure that when you order the locks through Summit or wherever that you get the right shank size (outer diameter) otherwise you'll have to grind them down to fit.
Old May 1, 2003 | 10:09 PM
Dr.Mudge's Avatar
Poly locks are for roller rockers. I'm not even sure they could be used with stock stamped rockers, although if you retain the oil ball I guess they could, dont quote me on that though
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
