donkey dong
Old May 1, 2003 | 09:48 PM
zuluman13's Avatar
donkey dong
what does the donkey dong do and why is it there also isnt it bad for the engine because it looks like air would just suck up into it unfiltered and it is the oval pice on the elbow right?
Old May 1, 2003 | 09:51 PM
Compstall's Avatar
The, uh, "donkey dong" is only a noise suppressor, nothing else. Yes you can remove it, but you need to find a way to plug it up. OR, just get a 1LE elbow that doesn't have one on it.
- Brent
Old May 1, 2003 | 09:54 PM
zuluman13's Avatar
does it suck dirty air into the intake because it doesnt go anywhere unless mine is disconected and i dont know it
Old May 1, 2003 | 09:56 PM
Compstall's Avatar
Your car won't run right if you don't have the hole plugged somehow, because the MAF won't be able to read the air coming in correctly. It doesn't suck in dirty air with the "dong" installed, it's pinched off at the end if you haven't seen that already.
- Brent
Old May 2, 2003 | 08:09 AM
RedWolf's Avatar
i removed mine months ago and instead of going out and getting the 1LE..i just drilled 7 holes through rubber and used SS screws, washers and nuts to seal up the hole and then i used a sealer to make sure it was totally sealed.
Old May 2, 2003 | 08:43 AM
rocmemphis's Avatar
Pert Plus shampoo bottle top works perfectly. Just use that and some sealant and then duck tape it to make sure it is sealed. Did that to mine over a year ago.
Old May 2, 2003 | 08:47 AM
ba96ta's Avatar
Great minds think alike I also have the "pert plus" intake mod. I did that after installing my electric waterpump
Old May 2, 2003 | 09:41 AM
Bud M's Avatar
Originally posted by Compstall
Your car won't run right if you don't have the hole plugged somehow, because the MAF won't be able to read the air coming in correctly....
He doesn't have a MAF. If that hose in the elbow is open you are letting unfiltered air into your motor. Plug it or get the 1LE elbow. I made a plug. Pics in my sig.
Old May 2, 2003 | 09:47 AM
teke184's Avatar
personally i'd like to someday hide my n2o nozzle inside the opening...nice and stealth...hard to detect...
hehe
Old May 2, 2003 | 05:10 PM
zuluman13's Avatar
Stupid me i Didnt realize that it was pinched off at the end and I know you have to plug it up if you remove it but what advantage does that give you.
Old May 2, 2003 | 05:36 PM
Dr.Mudge's Avatar
I used an Herbal Essence bottle bottom, worked great. Eventually got a 1LE unit because the old one was a bit soft.
It gets it out of your way, nothing more. If you had an electric pump, you'd need to eliminate it.
Old May 2, 2003 | 05:40 PM
9TransAM4's Avatar
theres really no problem with the "donkey dong". i just recieved my 1LE intake elbow today and put it on, but that is because my other elbow tore. i say keep the one you have, and if/when the time comes that it tears. go for the 1LE elbow. it is nice having that damn dong thing gone though
Old May 2, 2003 | 05:41 PM
Buttercup's Avatar
It makes you cool
Removing the dong isn't going to give you any performance. You have to remove it when installing an electric waterpump. Since the stock bellows tend to rip easily many people just replace with a 1LE when that happens. Other than that.... it doesn't do any harm having it there, other than being a bit ugly and slightly more of a PITA when removing/installing the bellows.
Old May 2, 2003 | 06:12 PM
Ernster500's Avatar
MBA offers a plug for the hole. It's not cheap though. You'd probably be better off getting a 1LE elbow like everyone else has stated. You can get them pretty cheap from Jason Cromer. eBay has them every now and then too...
E
gtheftz28
Apr 4, 2004 12:37 PM
GOATCRAZY
Sep 17, 2003 12:02 PM
BottleFedZ28
N2O Tech
Sep 14, 2003 08:16 PM
IGotThaPoPosZ
Jan 30, 2003 08:27 AM
Tim 97Z
Dec 1, 2002 06:52 PM
