Will I exceeded 100% injector duty cycle??
Old May 1, 2003 | 12:25 PM
quicksilver97ta's Avatar
Going in: XE230/236, 1.6 rr's, heads by Lloyd,
Already have: FLP headers, 4.11's
Anybody with the same or similar set up exceeding 100% injector duty cycle with stock FPR and stock injectors?
If I need to bump my fuel pressure a little to keep my duty cycle under 100% I'll put an AFPR on now while its off the car but thats only if there is NO question. My fuel pressure is within specs, I checked it just before begining tear down.
Old May 1, 2003 | 10:15 PM
TTT for the night crew.
Old May 1, 2003 | 10:20 PM
Dr.Mudge's Avatar
Unless you take the RPM down to 5k or so, you need new injectors. You can cheat with fuel pressure, for awhile - but the problem you run into is a shorter pump lifespan, some people are lucky some aren't, but our pumps weren't made for 60psi.
mightymouse383
Jul 20, 2016 07:34 AM
