SES Light Help
Old May 1, 2003 | 01:51 PM
Tumbler96TA's Avatar
SES Light Help
I had my SES light come on a few days ago and finally got to autozone to get it scanned. It's throwing a P0400 code EGR flow malfunction. what does that mean and how do i fix it.
Old May 1, 2003 | 02:43 PM
What does your exhaust system look like? If you have a low restriction exhaust, that code is often caused by inadequate EGR flow, due to the reduce backpressure in the system. If you have stock exhaust, I believe there was a recall on some of the OBD-II EGR systems.
Old May 1, 2003 | 02:49 PM
it's the stock exhaust system but i think i might have a small leak somewhere near one of the Y-pipe conections
Old May 2, 2003 | 03:26 AM
TTT
Old May 2, 2003 | 03:34 AM
chasmanz28's Avatar
Originally posted by Tumbler96TA
TTT
yes there was a recall i had my done last year, so check to see if your car has one, if not it needs either to be cleaned, or replaced, they retail for around 50 bucks
Old May 2, 2003 | 08:44 AM
EviLBoX's Avatar
If your car isn't covered under the recall, just remove the EGR valve and clean it with some carb cleaner, carbon buildup may be causing it to stick.
Old May 13, 2003 | 09:06 AM
chris96ta's Avatar
same thing happened with my car. Just got it scanned at auto zone yesterday. So just take the egr valve out and clean it with carb cleaner? Sounds easy enough but my question is how do you get to it? That thing is really back there. I can barely even get my hand back there.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
