cant spin the tires? 94 z
Old May 1, 2003 | 06:26 PM
sabre81's Avatar
just bought a 94 z28 auto and this may be normal but i can not spin the tires from a stand still. in my old 91 ford thunderbird sc auto which had about 225 hp and 320 lb ft of torque i could light em up just from mashing the gas to the floor at a light. Is my new Z not able to do this? if not why?
thanks
Old May 1, 2003 | 06:50 PM
Lunarson's Avatar
That doesn't sound normal to me Mine usually spins differently in different situations more or less but on street tires it will spin to a certain extent regardless.
Old May 1, 2003 | 06:53 PM
Tirefryin94z's Avatar
Yea, something seems funny. Almost any car will spin the wheels a bit when you punch it from a dead stop. Did you make sure 4 of the plug wires arent disconnected?
Old May 1, 2003 | 06:55 PM
mortal z28's Avatar
in the summer when the streets are really hot i can mash it from a light and barely spin at all before taking off, but in cooler weather it posis up and starts sliding sideways without moving forward very fast.
Old May 1, 2003 | 07:02 PM
sabre81's Avatar
the car doesnt seem slow, however i have never been in or driven a z28 before. i have hugeeee 255's on the back 2. it has been reasonably cold here (about 40-50). And i have yet to spin them on dry pavement. How can i tell if the car is lacking power, and what should i look for?
thanks
Old May 1, 2003 | 07:04 PM
MistaClean's Avatar
Yeah there is something wrong with the car. IT IS LACKING POWER....there are some many things it could be....any SES light?
Old May 1, 2003 | 07:08 PM
sabre81's Avatar
yes actually i got an ses light about 3 times . totally random. and there is a bit of a fuel/exhaust smell. i was going to take a look at the evap canister thingy. what else could be the prob?.
thanks
Old May 1, 2003 | 07:54 PM
sabre81's Avatar
any ideas on what to look for? i will scan codes tomorrow.
thanks
Old May 1, 2003 | 08:25 PM
TMDZ28's Avatar
i think it's running lean.....my 94 z can not spin the 215 on the back sometimes......lack of torque, but sometimes, it can spin the tires all the through 1st gear.......i think my opti is bad...you might wanna check that......good luck dude
Old May 1, 2003 | 08:30 PM
ram air camaro's Avatar
are your tires z rated and do you got the 2.73 gears, that combo will defitnely not spin your tires.
Old May 1, 2003 | 08:43 PM
9TransAM4's Avatar
i have 2.73's and i have no problem spinning the tires from a stop. i doubt that is his problem
Old May 1, 2003 | 08:45 PM
jasons93z's Avatar
your tires will still spin with that combo
Old May 1, 2003 | 08:46 PM
KeVMaN's Avatar
wouldn't z rated tires be easier to spin because they're harder?
Old May 1, 2003 | 08:49 PM
Jake77444's Avatar
Z rated are more sticky and a softer tire i believe, therefore they burn up faster too.
Old May 1, 2003 | 09:05 PM
Topdownback's Avatar
My 95 will get spin thru 2nd with traction control shut off. Not sure on 94 but if it has ASR (traction control) you need to shut it off mine has a switch but you may need to pull the relay, anyone else familiar with this
