before i change my fuel pump....
Old Apr 30, 2003 | 06:30 PM
nB5sP's Avatar
do you guys have any tips or things i should look out for before i start taking things apart?
thanks
Old Apr 30, 2003 | 07:36 PM
Notford95's Avatar
MAKE CERTAIN you get the retarded fuel level float back on. Then check again like seven times to make sure. Also, make certain you disconnect the battery. I forgot to do both the first time. You will have to pull the tank again if you do not get the fuel level float back on right (basically doing 95% of the work again for no reason). Good luck.
Matt
DirtyDaveW
Dec 1, 2016 05:37 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
Jul 4, 2005 05:00 PM
