What happened when your opti died?
Old Apr 30, 2003 | 09:13 AM
94foormula's Avatar
I know alot of us have had our opti sparks die on us. What happened when yours went? Ill have to check my fuses but mine went as I was driving down the throughway and I heard a loud pop...the car then died etc and now just cranks over, and over.
So how did yours go on you?
Old Apr 30, 2003 | 09:19 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
new engine
that was the only time mine was replaced...
120k miles....:::knocks on wood::
Old Apr 30, 2003 | 09:28 AM
thermwood1's Avatar
Mine went from my water pump puking antifreeze all over it.
Also want to give Jason Cromer and Tim at Sam Taylor Buick Dealership a big appreciation. Both are great guys to work with. I ordered my opti from Jason and got it 2 days later like i requested. After i installed it, i had problems with the car starting and idling rough. So i took it out to make sure the cam dowel pin was aligned correctly, and then reinstalled with the same problems. I eventually reinstalled the old opti, which would allow the car to fire up. I talked to Jason today and he is sending me a new opti and then i can send him the bad one back. Thanks guys.
Old Apr 30, 2003 | 10:15 AM
Type_O_Negative_1320's Avatar
Ditto...mine died the same way. I was surprised that it hadn't bombed earlier considering the bearing was terribly loose and the rotor had eaten halfway through the cap. I switched to the '95+ style opti with a kit from Jason Cromer (cheap!).
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
beltrunner
May 17, 2015 10:18 PM
rocknroler69
Apr 29, 2015 10:24 PM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
