How to stop heater hoses from leaking coolant?
Old May 1, 2003 | 04:09 PM
95BlackTA's Avatar
I just did the heater core flush, and put on the new clamps that you screw down(not the crappy stock ones)...well its leaking, and i think ive tightened the clamps down as much as I can...is there something that you put on the hoses that seals it to stop it from leaking?
Thanks guys
Old May 1, 2003 | 04:16 PM
BUBBA's Avatar
If the hose is the stock one, it jsut should not leak if you have ends all way on and the clamps tightened in the correct spot on the pipe (if the pipe has expanded ends). If that doesn't work try using double clamps. Good luck.
calaban
May 18, 2020 06:43 PM
dalynchmob
Feb 19, 2015 07:20 PM
Jlo
Feb 3, 2015 09:41 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
