Now i am mad
Old May 1, 2003 | 02:13 PM
blackz151's Avatar
Now i am mad
ok when i first got tthe car few dayz after it ran like crap. POPING a backfireing and missin. So we found that the water pump wuz leakin so i changed evey thing. pump opti msd wires plugs the hole 9 yards. Started it up it wuz still popin is missing. Come to be it wuz a bad 02 senor. Ran fine for months. Now its doin the same damm thing again. I got a code of a left o2 senor failed. So i chaged out the 02 senor and its still doin it. Any one got ne idears
Old May 1, 2003 | 02:25 PM
What was the specific code? Not all O2 sensor codes mean the sensor is bad. It might be a problem elsewhere - for example a leaky exhaust, misfires that is causing the sensor to misread the exhaust and add fuel that isn't needed, making the problem worse, and driving the long term fuel corrections to the limits, where they set the "O2 sensor lean" code.
If you have the specific code, it might indicate where the problem is, if its not actually the sensor.
NewsBot
May 29, 2015 01:40 PM
95z_28_camaro_4_Ivan
May 10, 2015 09:28 AM
nosliw
Apr 26, 2015 02:13 PM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
