Oh Shi! I dont think that was suppost to happen!!
I tapped a sensor in the block By the oil pan and it fell off! It looks like a o2 sensor but it is not. and it has a heat shield over it can anybody tell me what that is. It is not the one in the pan its in the Block.
Originally posted by 96ZRDR
If it had a heat shield sensor, then it is oil pressure sender (sensor). It is located on the block, just above the oil filter.
Originally posted by Kuppler
It might not be, the oil pressure sensor in my car is on the back on the intake not the block. I think he is talking about the knock sensor, just replace it and you should be fine.
I looked at a sight online and the knock sensor is by the starter and the oil presure sensor is correct and for all those who don't know the placement of the sensor varies from year to year. Just found that out.
(there is about 3 different sensors areas)
is your car a 93 then if so that was your oil pressure sending unit
i broke mine too when i frist got my car and was changing my plugs
if your car is cold dont start it it will SPRAY oil every where
dose your car have a factory oil cooler if not that it could be a reason or it might have been built early in the year who knows for sure but that is the only sensor that goes right above the oil filter
gm likes to get rid of stock on hand and there is some crossover
