A/C compressor
Old Apr 30, 2003 | 01:07 PM
dust6928's Avatar
A/C compressor
my compressor is not kicking on and i have checked the relays and the fuse. my question is, what wires do you jump at the high pressure switch to kick on the compressor? there is a red wire with 12v and a gray wire with nothing and a black wire i am assuming is ground if i am looking at the right thing. the high pressure switch is right next to the strut tower in between the drier and firewall, correct? i know if it is to low it wont kick on regardless but thi sis the last thing to check i suppose. any other ideas? thanks.
Old May 1, 2003 | 12:23 AM
dust6928's Avatar
well for those of you who may run into this in the future, i disconnected the neg bat cable for about 20min, plugged it back up and bam the compressor came on. i guess it was shut down by the pcm and since the compressor wasnt running after i got some freon in it resetting the computer so to speak allowed it to take another reading and see that there was pressure there and it kicked on. thanks for all the help!!!!!!!
2QUIK6
Sep 17, 2016 02:31 PM
magman
Apr 15, 2016 03:08 AM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
