cam question which one to go with
Old Apr 30, 2003 | 07:10 PM
hot936spd's Avatar
i want a cam for my car. i want a mild on for everyday driver/street car. something thats not too loapy. but you can still tell that i have a cam. and that will make a noticable diff. with out changing my opti. how many hours would it take to do?
my mods are
Cai, 3inch exhaust, 1.6rr. bbk shorties. new clutch . alum drive shaft. chip. low thermo. pulleys. msd coil.
Old Apr 30, 2003 | 07:20 PM
LimitedEd1LE's Avatar
I just got the Comp cam 224/230 on a 112 LSA and I love it. It has great mid range power all the way up to 6200. I got a whole kit from www.cmotorsports.com It cost about $100 more than the Hotcam but the springs are better than the ones that come with the Hotcam. You can definitly tell there is a cam in it, but it's not too radical. The hotcam is a great budget cam, but I wanted a little more beafy one.
Old Apr 30, 2003 | 07:22 PM
tanker's Avatar
I just started driving my car with CC306, and my first impression is that the car is perfectly streetable in low RPM's. Nothing unsusual, just a bit loud, but that's because I temporarily got bullet mufflers. Didn't try high RPM's yet, but that's where CC306 suppose to make all the power. Go with CC306, and you won't regret it.
I would suggest changing the opti, those things go bad opten for older LT1. It is quite a bit work in changing the cam if you doing it alone, and you never done something like this. It was timeconsuming for me, but at the same time I learned a lot. My friend madwolf helped me a lot, so if you can get sombody to help you who done this, you can get done in one day. Careful with oil pan gasket...
Tomas
Old Apr 30, 2003 | 10:20 PM
96blackbeast's Avatar
once I hit 4-5K she runs like a raped ape.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
