Does everyone's car actually shift where you have it set to shift at?
Do your cars actually shift where you have it set to shift. For instance.. say you have a mild cam and tons of other stuff.. you set your rev at 6600 with the hypertech and for your 1-2 shift to shift at 5800 rpm's, does your car actually shift or does it hit the rev before it shifts? This is the problem i am having... its done this since day one. Could it be the tranny or i am getting up to the speed quicker than my tranny can get there?
please helppppppppppppppp
thanks
-Mike
thanks
-Mike
i ran into that same problem with programming, i use lt1 edit. and what i learned is that the tranny doesn't shift until both mph and rpm points are reach then the pcm will tell the tranny to shift. you gotta love a4's. but i hope this helps and that i'm correct.
tim
tim
thanks....
at lunch i went and played around with it.. my 1-2 shift is set at
-6 and it shifted before it hit the rev limiter.. but my 2-3 shift still hit the rev so i set it at -11 but havent gotten a chance to test the 2-3 shift. hope this works
thanks
-Mike
thanks
-Mike
NewsBot
Dec 3, 2014 12:30 PM
