Oil Pressure
Old Apr 30, 2003 | 12:24 AM
RazorsharpZ's Avatar
Oil Pressure
What do your gauges read for oil pressure? Once my car warms up my gauge are almost in the red. Thanks for the help.
-Eric
Old Apr 30, 2003 | 12:42 AM
fbird95's Avatar
how much oil do you have in there. Maybe you need a new sending unit.
Old Apr 30, 2003 | 01:16 AM
chasmanz28's Avatar
whats the mileage on yr car, what weight oil do you use
Old Apr 30, 2003 | 06:06 AM
I have 89,000 miles on my car and i use mobile 1.
-Eric
Old Apr 30, 2003 | 07:48 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
-Eric
what weight
Old Apr 30, 2003 | 07:57 AM
You might want to try the search function. This matter is discussed frequently.
Old Apr 30, 2003 | 08:35 AM
My94RedZ28A4's Avatar
High mileage LT1's run low oil pressure. I have a 155,000 mile Lt1 that, when using 5w-30 Mobil-1 will idle hot, in drive, at about 10psi, which is right at the red. The manual specifies only 6psi at idle.
I now use Mobil-1 15w-50 or Castrol GTX 20w-50 and the oil pressure is back up to about 20 at idle and 40 cruising. Note this doesn't fix the problem, but it ensures that all of the oil doesn't squirt past the worn bearings.
Do a search, you'll get a lot of info.
Old Apr 30, 2003 | 08:49 AM
Est96Z28's Avatar
Could be bad sending unit or gauge, best what you can do, is to hook up mechanical gauge and check the real pressure. If it's less than 10 psi per 1000 rpm, then it is probably rebuild time. May try first just to swap in new oil pump.
Old Apr 30, 2003 | 08:55 AM
treyZ28's Avatar
id try a new oil pump WAY before a rebuild
Old Apr 30, 2003 | 09:10 AM
Est96Z28's Avatar
Yes, you are correct.
I had the same problem and tried new oil pump and unfortunately that didn't help much, athough old pump looked worned - that's why I think it's better to be prepared for rebuild.
Old Apr 30, 2003 | 10:33 AM
NOMAD's Avatar
Cool
HV oil pump, 7,000 miles. Cld, PSI is almost 70, warm at 2,000 rpm is 50. idle is about 25-30 psi
I would use a mechanical guage and check it before anything...
-Shannon
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
