Just got a Vig. got a few questions..Vig. Users inside...
Old Apr 30, 2003 | 06:26 PM
Whitewolf's Avatar
I just got a 9"3500 2.53 STR Vig. got my Formula. Was going to go with a Yank but a friend of mine had a bad experience with customer service so I choose another route.I have had good luck out of the SLP but wanted to go with a higher stall for my heads and hotcam setup. The questions I had is does anyone have a convertor with these specs? How do you launch? does it hit hard? Do you flash it? What is your setup and what kinda 60's and ET's do you pull? I ran 1.8's with the SLP hope to go high 1.6's with this one. Also I got a high stall fix so not worried about that. Just wondering about how your convertor is performing for you and about that 2.53 STR. Should be fun.
Also bought it off a board member 1QWKZ28
it has just been refreshed and he was very informative and helpful in my buying process. Good guy to deal with.
thanks Brad
Old Apr 30, 2003 | 08:15 PM
Smokn '94 Z's Avatar
Lightbulb
I am running a Vig 3600 stall now & cut low low 1.6 60' time with my set up in the sig. Not sure on the STR of my vert though. I stall it up at the track. I am still trying to figure out what optimal rpm to stall it up to but I know it is 2000 or more rpm. My problem with stalling it up is I am pushing through my weak LT1 brakes. I run 26 x 11.5 x 16 ET Streets & it just gets up & goes!!! I run better when I stall it up rather then flashing it.
What are the advantages or disadvantages to the different STR's?
Old Apr 30, 2003 | 08:21 PM
Ken95Z28's Avatar
The higher the STR the more punch you will have off the line. (If you great traction) The dis-advantage is the effeciency of the converter, the converter will be less effecient on the big end versus a converter with a lower STR rating. That usually means a loss of HP.
I have a 2.5 on mine and to me it pulls pretty darn good, but there are times I wished I went with something smaller like in the 2.0 to 2.2 range.
I usually stall mine up to 2300.
Old Apr 30, 2003 | 08:25 PM
Lightbulb
Yep. I just read the other post about STR's. Covnerter STR
Thanks Ken..
Old May 1, 2003 | 02:48 AM
Whitewolf's Avatar
yea I will probably be running the 26" ET's either those or the Hoosiers. I want to pull some really good 60's just think I am gonna have a blast launching this thing. Ken i have a video of your first 11 second pass 11.96 I believe..nice..I hope to be there with you soon..I am fighting a high rpm miss..gonna add a blaster coil and new wires..I will run high 11's I believe with traction and it tuned just right..hope so anyway..anyone else with a Vig.?
marlar98
Sep 12, 2018 07:18 AM
2QUIK6
Sep 17, 2016 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
92_RS_305
Sep 8, 2015 07:47 PM
maverickmk
Sep 1, 2015 09:17 PM
