View Full Version : LT1 Based Engine Tech
- Aftermarket coil on H/C car
- Oil pan drain plug thread
- Can't figure it out.
- door lock are not working after blowing/putting new acc fuse in
- Power Windows
- SES light really pissin gme OFF!
- Need Advice Fast..Please Help
- Splayed 4 bolt mains, and dipstick?
- Break Pads
- how can i flash the codes on a 93z
- headlights
- sidemarkers?
- Those with PCM modification
- New times tonight. (9/10/03)
- Time for a BIGGER Cam
- Torque
- Going to track-race gas?
- HELP!! My temp guage did the WEIRDEST thing tonight!!!
- horsepower
- track results of LE heads-xe 224/230
- which makes more power, cutout or catback...
- where to buy, or order indiglo gauge faces
- buy a F-body or not?
- rebuild after 110k
- Valve cover bolt torque spec
- T/A dash removal
- ***jet Hot Owners***
- Advice with cooling problem
- gutted cat
- Time for mods...need the info/opinions
- Question about Cut-Outs
- How can you tell if you have a spun bearing?
- BEARING the Truth ...
- Those who have LT4 starters in , please read.
- Fuel rail covers questions
- fan switch info (*different question)
- Measurements/specs for our wheels (such as backspacing, offset, bolt pattern, etc)?
- Fel-Pro 9966 PT head gasket (did search)
- who to call about custom cam?
- Exhaust System Upgrade Question
- Abs Inop Light Is Off !!!!!!
- Strainer (sock) part # for 255 LPH Walbro?
- True Duals.......Ousted Catz.
- Popping Noise
- Cut Off Exhaust On Lt1 Car
- Battery relocation kit?
- Catalytic Converter
- Back Pressure
- People with Long Tubes and Single Cat inside please
- Slowest 383 EVAR!!!
- What is the widest size tire you can put on an 8" rim?
- Ignition Coil?
- is it my opticrap?
- Friggin door
- HELP rear sway bar question
- Exhaust sizes
- tranmission cooler hose keeps busting
- changin heads with out new gaskets
- Header Gasket question
- Open headers/Back pressure/valves
- Where can I get a new opti?
- what Brand tires on 18x9.5 wheels
- Smog and 230/236 cam?
- borla muffler vs. flowmaster 80
- what lift is on your XE 224/230
- Advantages/Disadvantages of solid roller
- Help me make my 355 a stroker.
- Throttle Body problem or not?
- Putting threadlock(red) on rocker arm bolt?
- 383 vs. 396
- Will it fit??
- ABS wiring harness
- Power door locks don't work. What's the problem?
- Computer learning??
- Whats involved in a DIS ignition using LS1 coil packs???
- K&N filters and stuff
- injector question
- How to get the High, Low and Fog lights
- All you engine rebuild guys.......
- Stock Torque Converter stall?????
- header install without a lift?
- Borla catback install question
- Optispark...rotor??cap??
- No third gear? (700R4)
- How do I fix my TA's adjustable headrests from slipping?
- Do they make anything like this 4 us?
- Cant find why it's missing...
- slap head...feel dumb but how many quarts of oil do i put back in for oil change?
- Ruststang
- SLP Loudmouth(not typical)
- Mac Torque arm & Loop, Opinions?
- So is it my clutch or something else..*Help fast no ride for work*
- Low, Low RPM power
- Caprice Lt1
- Need a new Fuel Pump
- launching my A4 2.73 vert
- Does 2OTL have different I-Pipe?
- ls1 coilpack conversion???
- ARP Intake bolts which ones ?
- LT1 Turbo Vid
- rear main seal
- Window Lift Spring Problem
- Options for 2 -> 4 bolt
- lt1 camshaft in a small block Gen I
- 355 or 383
- Air Bag Suspension?
- probles at high RPM's
- Broken Power Programmer?
- installed magna flow today
- SES lght comes on every 45 mins
- **A4 OWNERS**thinking of getting a Lt-1 but how quick will the tranny go out?
- what do you guys think
- 23 degree heads vs 18...
- 425 RWHP 383, what's holding me back???
- Part no, hooker y-pipe
- Anyone know...
- New Plugs And Wires???
- Hey 97z-M6, Skardom and Dr. M.
- Weight of oil ??w-?? *best*
- Hurst Shifter question? Help?
- 1/4 of play in new timing chain, normal?
- I think my OptiCrap sparked out...
- Ported Heads but NOT Intake???
- lost alot of power..HELP
- Need some help here, getting really bad gas mileage (Long)
- Question For Jason Cromer
- I have an idea.....Mods please read
- Those with MSD Ignition
- Why wont a LT1 pass emissions with Long Tubes ?
- trans go's arent adjustable?
- How can you tell when the oil pump drive shaft is engaged?
- 16 lbs of Fuel Pressure - Did Pump or Regulator Die?
- Question Lt1 & Ls1
- What should i Dyno?
- Difference between dual and single cat headers?
- i need some help ???
- Does anybody have the CC304 cam on stock heads?
- corvette fuel rail covers
- lt1 to ls1 maf
- How much should I>>
- Building an LT1
- 1994 camaro b4c sway bars?
- 3 cables on the throttle body?
- Trying NGK TR55 IX
- Different fuels help???
- casting number for 561 head...
- Cold Air Induction
- Oval header collectors
- spraying 250......?
- Quick EGR ?
- different part numbers for diff year heads?
- Edelbrock heads arrived today..
- HP gains from ignition and chip
- Oil Pressure seems kinda low.
- Rear rotor/ rear end swap question
- Injectors size/replacement?
- Hey self Port and Polish dudes correct me if I'm wrong
- Which ARP bolts...Stainless or black ones?
- speedo/odometer reading half, and lockout gone?!?
- Comp suggested this cam. What do you think?
- Bad PCM or sensor on modded 95 Lt1/4?
- Thinking about a "custom" cc305
- Remanufactured LT1
- Need Custom Belt
- Ok I have a hard starting problem now..
- chambered true duals?
- Gears - did you gain any MPH?
- Spark question
- spark plug
- Fuel Lines
- Firehawk Springs
- harmonic balancer/timing
- Bolt on modifications
- Should I replace fuel filter?
- Weak 96 LT1....??
- OVC Wires
- Chevy dealer BSing me or what?
- 95 z28 OBD1 or OBD2
- Best brake fluid????
- 95Z A4 Shifting questions
- where do the valve seals go?
- LT1 intake status
- Does anyone sell 36 LB SVO Injectors anymore?
- 3 quick questions...pics inside
- Difference between headers
- how much more a cc 305 kit?
- Transmission swap clutch problem
- What values to look for when scanning?
- Rebuilding questions
- 1996 LT1 Impala high idle after plugs/wire/!AIR
- B&B Tri-Flow question?
- Ignition problems--95 Z
- clip of any exhaust w/shorties out there?? c'mon people we need some hard evidence!!
- Help! Why aren't my #'s better?
- Firehawk Lower Control Arms
- How to find the leaking coolant hose?
- Used lifters okay?
- How do you fix leaking/loose A.I.R tubes??
- Ordering Crate Engine from Combination Motorsports Tomarrow, have ?
- Will heavy wheels(18's) affect dyno numbers??
- 383 rotating assembly AND flywheel question (important)
- Remove ZO6 MAF screen
- maf to filter rubber fitting
- 383 vs 350 MPG
- Possible problems after.....
- roll bar in a vert
- how many miles on an LT1 before..
- Where to buy IAT?
- Whats under the plate on the bottom of the intake?
- rearend girdle torque specs.
- Weld in cage question
- Nick countrymusic calling nick- LT2 ?
- CM Motorsports
- Everything works fine.I just want the security light gone!How?
- Solutions to a squeaky Serpentine belt?
- Auto guys... what is your oil pressure at idle?
- Emissions with the 224/230
- install 1.6 rr's and cam
- How to Check your Fuel Pressure.
- Where do i get dino oil
- IAT relocater kit?
- Here's a question for all
- Part Number help please
- taillight part number?
- DoH! stripped header bolt..
- What is the H clip in the rear brakes for??
- limited slip troubles
- Best Ignition Coil?
- What 3000+ stall converters is everyone using?
- So what next....?
- High Idle, Adjusted Idel Screw On TB...helped till i revved the car????
- 3.73's or 3.42's???
- biggest tire you can run on a 17x8.5 rim?
- how much quieter are the lt4 valve covers to hide some of the noise
- Anyone using a ProTorque 9.5" non-lockup?
- camber problems
- Rearend Help Please
- OBDII??? Odometer reading???
- HELP....VATS disabled on PCM,where is VATS module to diconnect?
- Thanks Shoebox
- Replacing ignition switch...NEED HELP!
- which springs with lt?
- LT1 305 racing motor...
- Car stumbles and runs like crap before it shifts
- Does this sound like a good deal for 383 machine work
- Coolant just dont like to stay in the car
- Where can I get the cheapest IAC valve?
- When re-installing the balancer hub?
- Cheapest place to get a new LM?
- I have no idea....
