Rear rotor/ rear end swap question
Old Sep 9, 2003 | 02:44 PM
hambone3441's Avatar
Question Rear rotor/ rear end swap question
Well here is my situation, I installed a 2001 Trans Am/WS6 rear end in my 95 Camaro Z-28. I had to use the mounting brackets, calipers, and rotors from my car. In doing so the rotors now rubbed on the calipers. I circumvented the problem by installing 1/8 inch washers behind the rotors and works fine now being shimmed out a bit. I noticed that there are different part numbers for the rotors,calipers, and mounting brackets between lt1 cars and ls1 cars. Will a simple rotor swap (going to ls1 rotors)work for me here? Or do I need to replace the other components also. Any help would be great. Thanks.
1995 Camaro Z-28 K&N CAI, Throttle Body Airfoil, Hypertech Power Programing, Underdrive Pulleys, Edelbrock Headers, Flowmaster Exhaust, Richmond 3.73 gears, KYB AGX Struts/Shocks, Lakewood LCA's.
8.4 1/8 on MT et streets
Old Sep 9, 2003 | 02:58 PM
DarkHorse's Avatar
I had to buy new rotors and pads when installing my 2000 rear. Some fabbing was required to install the brake lines on mine however.
Old Sep 9, 2003 | 03:05 PM
chasmanz28's Avatar
check this post out, im sure chucky will help you http://web.camaross.com/forums/showt...adid=164907out
Old Sep 9, 2003 | 04:45 PM
The axles are different lengths. Whatever axles you are using, you should use the complete brake setup for same. IOW, if using LT1 axles, use all the LT1 brake stuff. If using LS1 axles, use all LS1 brake stuff. "Stuff" being backing plates, rotors, calipers.
Old Sep 19, 2003 | 03:09 PM
Would changing out just the rotors and pads work?
Old Sep 19, 2003 | 04:32 PM
Re-read my post above. Whatever axles you are using, you need all the brake stuff that goes with them. I don't know how to make it more plain.
Old Sep 20, 2003 | 04:45 AM
Thanks for the info, didnt have to come off that way though. Just wanted to do this the cheapest way possible since I have no functional problems now, did not want to spend a fortune on calipers, rotors, pads, brackets, etc. Oh well I will just keep what I got, thanks anyway.
Old Sep 20, 2003 | 08:27 AM
Sorry, I spend a lot of time answering posts. When it looks like people don't read what's written it makes me frustrated and wonder why anyone bothers to post. I'll try to be more understanding.
I have reservations about your particular solution as far as safety. A solid spacer covering the whole axle face would be better if you were going to do it without the correct axles.
Old Sep 20, 2003 | 09:10 AM
DiabloZ's Avatar
If you do decide to go with the 98+ parts I have a complete setup for the rear disc brakes ( fronts too) . all the parts together so it would be right. It's a much better brake setup anyway. Shoot me an e-mail if your interested.
oldschool
Feb 9, 2016 09:21 PM
blown94
May 3, 2015 12:48 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ChrisFrez
Dec 28, 2014 02:25 PM
Hurin
Dec 13, 2014 07:38 PM
