Remove ZO6 MAF screen
Old Sep 8, 2003 | 10:07 PM
97_TA_WS6's Avatar
Talking Remove ZO6 MAF screen
Hey guys I just purchased the ZO6 Maf from Sam Taylor the non programmed one and will have PCMFORLESS program it to work with my LT1. I will be also purchasing the pigtail from ramchargers.com. My question is this, there is one screen on the MAF and would it hurt to remove it. My stock LT1 doesn't have the screens. thanks
Old Sep 8, 2003 | 10:09 PM
got_hp?'s Avatar
there is no reason to remove the screen, it will no increase the airflow.
the screen helps make sure there is uniform airflow over the maf for proper readings, and stops any debris incase something got by the filter.
Old Sep 8, 2003 | 10:21 PM
ledfootz28's Avatar
yea i wouldnt take the screen out
Old Sep 8, 2003 | 10:23 PM
ROADRAGE's Avatar
A Z06 MAF with a screen? when did that start? I know they didn't have screens the first year
Old Sep 8, 2003 | 10:42 PM
97_TA_WS6's Avatar
well mine came with it, the screen is on the entrance side of the MAF there is no screen on the side that attaches to the throttle body. So it wouldn't make any difference with or with out it??
Old Sep 8, 2003 | 10:45 PM
96speed's Avatar
Cool
The 2002+ ZO6s don't have screens. I bought mine from Dal. I asked if there was a different part number for the later model ones - I am pretty sure they only have one part number now (no screen).
To answer the question - go for it .
Ryan
Old Sep 8, 2003 | 10:53 PM
got_hp?'s Avatar
REMOVING THE SCREEN WILL NOT GIVE YOU ANY PERFORMANCE GAINS
why do people have a hard time understanding this
Old Sep 8, 2003 | 11:19 PM
chpmnsws6's Avatar
would it give you any gains on a supercharged 3.8 (GTP)
we have one and i took the screen out when i put the k&n cone on it.... the combo picked up performance but idk if the screen helped it
Old Sep 9, 2003 | 11:29 AM
97_TA_WS6's Avatar
Thanks guys
Old Sep 9, 2003 | 11:35 AM
quicksilver97ta's Avatar
Ouch! That hurt my ears.
Old Sep 9, 2003 | 11:45 AM
96speed's Avatar
REMOVING THE SCREEN WILL NOT GIVE YOU ANY PERFORMANCE GAINS[/SIZE]
The 405hp ZO6 has a !MAF screen along with a few other tricks from the earlier 385hp one. Draw your own conclusions unless you have track/dyno numbers to compare.
Ryan
Old Sep 9, 2003 | 11:50 AM
97_TA_WS6's Avatar
Ok 96-speed I might sound dumb here but are you saying that the 405HP ZO6 doesn't have the screen??
Old Sep 9, 2003 | 11:52 AM
got_hp?'s Avatar
Ryan
ok.......this takes some basic logic......lets follow along
engine can intake X amount of air
maf screen can flow more greater than X needed by the engine.
the screen is not a restriction unless you have a very highly modded engine.
explain where the performance gains come from, since you are not increasing the amount of air?
Old Sep 9, 2003 | 12:46 PM
zhevy-1's Avatar
Can somebody post a part number for both the Z06 MAf and the Pigtail from Ramchargers? Also, price if you would too.
Thanks.
Old Sep 9, 2003 | 12:57 PM
96speed's Avatar
Lightbulb
Suck in air through a .5" pipe then through a 4" pipe. Why do guys put a larger airfilter on?
My turn...
Why do aftermarket MAF sensors come without a screen?
Why did GM remove the screen the newer LS6s (that make more HP).
You can say it doesn't help all you want. I can say it does help until I'm blue in the face. Until you or I do a dyno/track test back to back with each MAF, its silly to get into a pissing contest. I'm using logic (posted above) to base my claim that, however small, it helps.
Ryan
