How to find the leaking coolant hose?
Old Sep 8, 2003 | 11:10 PM
95BlackTA's Avatar
After I drive the car i jack it up and get under it, but can never find the leak..cant you spray something on there and you will be able to see air or coolant escaping? Thanks.
Old Sep 8, 2003 | 11:14 PM
Transamdriver's Avatar
Get some dye that shines in black light and add it to the coolant. Then get a black light and find the leak.
Mr Kevlar's Avatar
I assume that you see a puddle on the ground after driving? Where is that puddle located in relation to the motor?
Old Sep 8, 2003 | 11:18 PM
95BlackTA's Avatar
Well I park in the street, and my last car had a major oil leak. I need to throw some cardboard under there and check to see, but so far i have seen nothing on the ground. Some ppl said it can leak into your frame, and then spill out when you drive...im not sure, but i gotta find a big piece of cardboard and check that out i guess.
Old Sep 9, 2003 | 04:58 AM
Van5150's Avatar
If you dont see any coolant on the ground, why do you think you have a leak? Are you loosing coolant ?
Old Sep 9, 2003 | 06:01 PM
95BlackTA's Avatar
Loosing coolant very fast...when im driving it everyday, I have to refil it like every 3 or 4 days. Even after I drive it one day and it sits for a few, it will still be low when i open it up.
Old Sep 10, 2003 | 06:48 AM
Van5150's Avatar
Do you see white smoke out the exhaust?
Old Sep 10, 2003 | 08:09 AM
bt95formula's Avatar
I had the same problem with my 95. It wouldn't leak when the engine was cold but it seemed like when the thermostat would open, it would leak out of the bottom of the w/p. Had to replace the w/p to fix the problem
Old Sep 10, 2003 | 08:36 AM
markzman97's Avatar
Theres a kit you can buy that has different types of dyes, it comes with small black light and glasses that help see the dye. I seen it on one of the car programs on TV not sure price or stores.
Old Sep 10, 2003 | 11:52 AM
moparman's Avatar
Pep Boys sells the coolant leak detection kit. Cost is about $50.
calaban
May 18, 2020 06:43 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
cristian1311
Nov 23, 2014 02:22 PM
