gutted cat
Old Sep 10, 2003 | 09:16 PM
ramair94ta's Avatar
gutted cat
I was thinking of pulling my 3" cat and putting a gutted one that i have on the car . I was told it has a new high flow cat, not sure if its true. With the gutted one will the car gain any power or sound from this.
thanks
Old Sep 10, 2003 | 09:18 PM
Cmr0z28's Avatar
it will be louder, raspier, less low end torque, more popping noise, and maybe slightly more HP in higher RPMs.
Old Sep 10, 2003 | 09:19 PM
RamAir95TA's Avatar
Nice screen-name.
You'll gain a handful of ponies from it, and you'll notice a raspier and louder exhaust note. Some think it sounds great, while others do not. A straight-pipe would be a better alternative, to minimize exhaust turbulence.
Old Sep 10, 2003 | 09:21 PM
Z95m6's Avatar
i actually lost hp thanks to my offroad pipe. When i put my motor together i had several degrees of KR then when i put a cat, back on the KR went away. It felt way stronger after that.
Old Sep 10, 2003 | 09:28 PM
ramair94ta's Avatar
any one else , 2 good , 1 bad. I was ready to run out and do it then z95m6 posted.
every time i see your sceen name i think its my postbut then again yours is newer
Old Sep 10, 2003 | 09:30 PM
ramair94ta's Avatar
I forgot top write that the car is stock, only mods are filter and 3" flow master exhuast. this might help
Old Sep 12, 2003 | 07:03 PM
ramair94ta's Avatar
the gutted cat seems to help out on the bottom end and the top end, i have a little more pull on the top end for sure.
Old Sep 12, 2003 | 10:53 PM
Camaro_Maniac63's Avatar
Gutting the cats doesn't do jack for the car's performance. I am just polluting the environment more, and after the headers, my car doesn't sound all that impressive. Don't do it, it is a waste of time. If you want to do something good, get a off-road pipe.
Old Sep 13, 2003 | 11:26 AM
mazer3800's Avatar
My cat is gutted and the whole car smells like gas at times. Especially sitting at a light, my guess is that the wind blows it into the cabin. Either that or something else is wrong with my car . I'm definatly thinking about going to an aftermarket cat.
Old Sep 13, 2003 | 11:37 AM
jasons93z's Avatar
I gained quite a few HP from my ORP, and i didnt notice any loss in the low end. And i love the sound.
Old Sep 13, 2003 | 12:43 PM
ramair94ta's Avatar
It seems to help mine out. As for the gas smell i have the same thing but it was there before i changed the cat so i dont think thats it, you must have the same problem that i have .
Old Sep 13, 2003 | 12:52 PM
jasons93z's Avatar
i dont notice much of a gassy smell
Old Sep 13, 2003 | 12:57 PM
ramair94ta's Avatar
no , no, mazer3800 said he gets a gas smell , i had the gas smell before i did my cat so i know its not the cat. not sure what it is
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
