Used lifters okay?
Old Sep 8, 2003 | 11:03 PM
NAZTLT1's Avatar
Used lifters okay?
I can get a set with less than 20k cheap. I have 80k on mine and one is tapping. Can't figure out which one though.
Old Sep 8, 2003 | 11:07 PM
LimitedEd1LE's Avatar
I wouldn't do it. I dont trust any used engine parts. There are too many things that could have happened to them.
Old Sep 8, 2003 | 11:08 PM
J's 82's Avatar
I second that..
Old Sep 8, 2003 | 11:27 PM
NAZTLT1's Avatar
Where's the best place/ price to get sbc hyd roller lifters for an lt1?
Old Sep 8, 2003 | 11:35 PM
www.summitracing.com has great prices and they ship very fast. I would get the Comp Cam lifters. I think they are around $180.
Old Sep 8, 2003 | 11:39 PM
J's 82's Avatar
I just got a set of Crane Cams rollers from Jegs.com took the part number from thunderracing.com and cross referenced it and found Jegs was cheaper by a few bucks for that brand lifter..
part number 270-10530-16 at jegs.. the year applicable is wrong but it is the right lifter.. $169.99 for the set.
Old Sep 9, 2003 | 12:33 AM
NAZTLT1's Avatar
Thanks for the good info.
Old Sep 15, 2003 | 02:55 PM
WheelmanZ28's Avatar
I was dumb enough to re-use my stock lifters when I did my cam install, and I suffered from very low vacuum pressure after the cam as a result. I went back and installed Comp Cams Pro Magnum Lifters, which are less than $20 more than stock OEM lifters, for a replacement. Car runs good now with great vacuum and no loss of power at Upper RPMs anymore.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
