Injectors size/replacement?
Old Sep 9, 2003 | 02:22 PM
kevmor99's Avatar
Question Injectors size/replacement?
My injectors are dirty, one cylinder doesn't hardly fire off idle. A place that cleans and flow tests them wanted $35/ea. What is the stock size injectors for a 95 LT1? 24/lb? I think I might just get some good used ones.
Old Sep 9, 2003 | 02:34 PM
chasmanz28's Avatar
Re: Injectors size/replacement?
24lbs is correct
Old Sep 9, 2003 | 02:36 PM
kevmor99's Avatar
If I end up getting good used ones, should I go for a higher rating? Ford injectors? I can modify the flow field w/ Tunercat, is there anything else I would have to do for a stock engine? Or is this a bad idea getting larger ones...
Old Sep 9, 2003 | 02:38 PM
J's 82's Avatar
From what I understand 24lbers are good to 400hp.. though I hope one of our resident tuning experts will chime in..
In my case I am running Accel 24s and have had no problems with them..
As for used ones.. you should have those flow checked anyway..
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
