Solutions to a squeaky Serpentine belt?
Old Sep 8, 2003 | 08:13 PM
F(ast)-body's Avatar
Squeeks every so slightly...anyway to prevent it?
Old Sep 8, 2003 | 08:23 PM
FireAm94's Avatar
Did you check for a very small fluid leak? I had a power steering leak that was ever so slightly spraying fluid on the belt.
Joe
Old Sep 8, 2003 | 09:34 PM
revtime's Avatar
I had a belt squeak for over a year after I put in the underdrive pulley. No matter what belt I used it did not help the situation, Gates, Dayco, etc, none of them would be quiet.
Then Goodyear came out with the Gatorback belt, I finally got hold of one that would fit and no more squeak.
Old Sep 8, 2003 | 09:54 PM
Mr Kevlar's Avatar
Try some belt dressing. Could even be a leak from one of the belt driven accessories like stated above. Could even be a pulley bearing on your Alternator, PS Pump or AC Condensor.
Old Sep 8, 2003 | 10:08 PM
SinisterSS's Avatar
Get a new Good Year Gatorback belt. Got mine at AutoZone for under $25 if I remember correctly.
Old Sep 8, 2003 | 10:38 PM
atljar's Avatar
Try a tad of WD 40 on the belt, then hold a rag against it while its moving. WARNING: BE VERY CAREFUL YOU DONT GET YOUR FINGER CAUGHT OR THE TOWEL CAUGHT IN THE BELT!
This will clean the belt really well, and more than likely fix the problem. Dont use belt dressing, that stuff makes a huge mess
Old Sep 8, 2003 | 11:12 PM
J's 82's Avatar
Could also be the tensioner on its way to the morgue..
Old Sep 8, 2003 | 11:17 PM
Fatdog's Avatar
Cool
Ditto on the tensioner.Might just hit the belt ever so gently with wd -40 (one quick spray)about 2 times,and see if that helps.Do the new belt thing first though.,Napa=great prices.My02
Old Sep 8, 2003 | 11:19 PM
Fatdog's Avatar
Cool
Another thought,why not just hit the tensioner ever so gently with wd-40,and see if this really is the culprit.Hope this helps.
generaldave
Sep 25, 2015 06:48 PM
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
