1/4 of play in new timing chain, normal?
Old Sep 9, 2003 | 07:51 PM
$hawn's Avatar
I got a new timing chain and new cam gear, still factory crank gear, and theres about 1/4 of play, seem normal? I didnt measure how much was in the factory one but it seemed to be about the same.
Old Sep 9, 2003 | 09:11 PM
xchief1320's Avatar
1/4" on only 1 side of the chain seems pretty normal to me...Now if you had 1/4" on EACH side then that might be a lil loose..
Steve
Old Sep 10, 2003 | 10:24 PM
arnie's Avatar
If you believe it is excessive, and the crank gear has little or no wear, an oversize crank gear from cloyes is available.
Old Sep 10, 2003 | 10:43 PM
$hawn's Avatar
I figured out what was wrong, once I tightened down the bolts it was tighter, now theres about 1/8" play, still kinda loose, but not to where it seemed like it would jump a tooth. From what I hear most will always be a little on the loose side.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
