Popping Noise
Old Sep 10, 2003 | 04:52 PM
cadesso's Avatar
Popping Noise
Hi guys,
I need some help here. I have a '96 SS with 10K miles on it. The other day I started it up and headed down the street and when I let my foot off the gas I got this big POP!! I dont think it is a back fire because it would happen when I was on the gas. Any ideas?
Old Sep 10, 2003 | 05:04 PM
RamAir95TA's Avatar
Whereabouts did the sound come from? It might be that you have a busted transmission mount if it came from the console, and sounded like a "thump."
Old Sep 10, 2003 | 06:11 PM
cadesso's Avatar
It comes from the exhaust, sounds just like a backfire!
Old Sep 10, 2003 | 06:14 PM
BlakeW5's Avatar
That's no big deal, every f-body does that. Totally normal. Certain exhausts can make it worse though.
Old Sep 10, 2003 | 06:15 PM
jakesnake123957's Avatar
popping
try checking your coil wire and plug wires and plugs.If valves are too tight it can pop too.
Old Sep 10, 2003 | 07:30 PM
cadesso's Avatar
Thanks Guys, I just took it out and heated it up a little and knoticed that it is much less significant after the motor heats up. I was thinking maybe I have a vaccum hose off somewhere?
Old Sep 10, 2003 | 07:45 PM
Cmr0z28's Avatar
that's what the AIR pump is for.....it helps the cats heat up. once they're heated up there is a significantly less amount of popping. you should hear it with my cutout! sounds like fireworks are going off under the car when im doing 80 / let my foot off the gas and when i get back on it, BOOM!!!!!!!! lmao
Old Sep 10, 2003 | 07:47 PM
Abuzah's Avatar
I've got the same kind of deal. It's only happened a few times, but if I just start it up and get going, sometimes on the 1-2 shift it'll kind of clunk. I can really only hear it if the window's down. It's only done it once or twice in the few times it has happened, then it goes away. So I figure it's not that big of a deal. *shrug*
Old Sep 10, 2003 | 08:30 PM
97Formula's Avatar
With my cut-out, when my engine is cold, the backfire sounds like gunshots and it backfires less when it warms up with no loud pops. Its perfectly normal, even when I cap mine, my "quiet deep sounding" muffler backfires. I've heard many new SS' with stock exhaust still backfire as well, but if you are worried, i'd check your coils and wires, but I don't think that's the problem.
Old Sep 10, 2003 | 09:38 PM
Johnnynsac's Avatar
My car backfires loudly when cold, a few times when warm.
Do you guys know what causes backfire. Is it fuel thats being burnt up or something like that?
Old Sep 10, 2003 | 09:40 PM
RamAir95TA's Avatar
A backfire is unburned fuel mixture being ignited in the exhaust system.
Old Sep 10, 2003 | 09:42 PM
Johnnynsac's Avatar
And certain exhausts can make it worse?
Aaront810
Aug 29, 2020 09:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
autoxr166
Sep 25, 2015 04:21 PM
Toxintwins
Sep 11, 2015 11:13 AM
