tranmission cooler hose keeps busting
Old Sep 10, 2003 | 02:59 PM
rage366's Avatar
this is the THIRD time the hose for the cooler has busted in 2 months!! the tranny is rebuilt...i made sure the tranny cooler wasnt clogged when i first installed it.
i've been using rubber hoses so far...i'm gonna upgrade to braided hoses.
could the rubber hoses be too weak for the tranny line pressure exerted?
Old Sep 10, 2003 | 03:38 PM
TreySpeed's Avatar
On permanent vacation
Re: tranmission cooler hose keeps busting
My silverado has no problem running rubber hoses I'v never heard of such a problem.
1 thing that would cause it to pop off - well that i can think of
pressure. Pressure due to head or from the trans pumping hard
did you clamp dow the hoses?
Old Sep 10, 2003 | 04:14 PM
rage366's Avatar
Re: Re: tranmission cooler hose keeps busting
yep, hose was clamped down real tight...
i'm just gonna take off the cooler and see if it's clogged up or something...only thing i can think of...
Old Sep 10, 2003 | 04:33 PM
RamAir95TA's Avatar
What kind of cooler are you using?
I'd think a good tight clamp and a clean barbed fitting should be more than enough to retain the pressure. Are you sure you installed the lines correctly? I'd imagine if you didn't connect the return line properly that pressure could build up and blow off the hose.
Old Sep 10, 2003 | 05:07 PM
rage366's Avatar
i think i figured out why the damn thing keeps busting!
the rubber hose isnt big enough...at the tip of the cooler, the diameter is bigger than the rest of the cooler line, so when we force the smaller rubber diameter hose on that bigger cooler tip, the rubber is stretched too much and weakens, and causes it to pop after a while...
Old Sep 10, 2003 | 07:13 PM
ZLT195's Avatar
A rubber hose with regular clamps will be fine.
I had to splice one of my steel lines that comes from the tranny to the radiator and I did it with a rubber hose and just used regular hose clamps.
I plan on fixing it right in the future but I have had the tranny downshift hard into first (A4) many times and it has never even drewled...lol
Z~
Old Sep 10, 2003 | 08:12 PM
rage366's Avatar
Z~
unfortunately, my tranny line isnt behaving nearly as nicely as yours...3 times in two months!!! that has to be a record..
oh yeah, what size hose did you use?
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Fatdog2
Sep 16, 2015 11:04 PM
