IAT relocater kit?
Old Sep 8, 2003 | 07:28 PM
Got-LT1's Avatar
IAT relocater kit?
Anyone ever hear about it? It's in the new jegs on page 94.
From the magazine:
"Relocate your temperature sender further away from the engine for a cleaner reading. Improves throttle response and HP is increased along with improved driviability. $39.99"
It is made by Jet performance products. Is it worth a damn?
Old Sep 8, 2003 | 07:54 PM
ibanez6rg's Avatar
Don't waste money on a $40 kit. Pretty sure you can do it for practically free.
Old Sep 8, 2003 | 08:35 PM
thermwood1's Avatar
Not really worth doing, but if you really want to.
All you have to do is take the one out of the air intake, splice longer wires in, and relocate to air filter area. That's it.
Old Sep 8, 2003 | 08:41 PM
QCKZ28's Avatar
i used superglue and a plastic trim panel screw with a head big enough not to go through the IAT hole in the elbow, i used speaker wire to extend the IAT wire to the K & N conical filter, and drilled a hole in the end of the filter just barely big enough for the IAT sensor. it very easy and doesnt cost $40
i think it was the 2nd mod i ever did
Jesse
Old Sep 8, 2003 | 10:16 PM
Fuels94TA's Avatar
Dont waste your money when you can do it free. All it is just wire about 12-20 inch long (depends on where you install it). Drill a hole somewhere by the filter, re-install the IAT into the new location. Then plug up the old hole. Take's about 30-45 min. to do it.
Vinny
Old Sep 8, 2003 | 10:41 PM
WhiteThunderZ28's Avatar
It took me 10 mins to do and i also used speaker wire.... After I installed it a started the car and let it idle for a few mins so the computer can read the cooler air then i reved it a few times an back fired though the air intake so Igave it a few more revs and it was fine...
I heard that if you did the relocation of the IAT that the colder air will make the computer/ car run richer... Any truth to that?
But i did notice a better throttle response if that helps.
Old Sep 8, 2003 | 10:49 PM
Got-LT1's Avatar
I usually don't deal with wires, but I'll give it a try. I just wanted to know if anyone had heard of it.
Old Jul 5, 2004 | 10:39 AM
rob96TA's Avatar
No one has stated the gauge of wire used.
Don't know why but speaker wire doesn't sound right to me, any differance.
I was thinking maybe 18 gauge? Anyone else?
Old Aug 2, 2004 | 09:45 AM
rob96TA's Avatar
Re: IAT relocater kit?
ttt
Old Aug 2, 2004 | 10:20 AM
Relocating the IAT sensor in the MAF cars (94-97) has been a common mod for many years. The stock location of the IAT subjects it to heat soak, and if the temperature gets high enough, it will pull up to 3degrees of ignition advance.
Relocating it to a remote part of the CAI helps eliminate the problem.
In general, using speaker wire for a mod like this is "ghetto" at best. You need wire suitable for an automotive application, oil resistant, high temp insulation, etc. The current in the IAT sensor circuit is very small, but it is a good idea to use a wire gage at least as heavy as the stock wiring, or even one size larger. The PCM is reading the circuit resistance, since the IAT sensor is a "thermistor".... a resistor whose resistance changes in inverse proportion to temperature. 14 or 16 ga. should be fine.
In a MAF car, it will not alter A/F readings... the IAT is not used for A/F calculations in a MAF setup. The 1993's will alter the calculations for the speed-density A/F control, since IAT is one of the elements that goes into the "density" part of the equation.
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
CARiD
Jul 7, 2015 08:19 AM
BinkZ28
Apr 20, 2015 09:10 PM
