Rebuilding questions
Old Sep 9, 2003 | 12:26 AM
SilverTA2813's Avatar
I am buying a 90k mile lt1 engine and i am going to rebuild it and drop it into my 96 TA. This is what i want to do to it
lt4 heads(assembled)
cc306w/1.6 rr
chromemoly pushrods
lifters
I also want to replace the whole bottom end. I dont have alot of cash so i want to go cheap on the bottom end. Can i just put new stock pistons, crankshaft, rods ect in without having to bore my cylinders any? If i went with a stock crank and pistons do i still need to have my crank balanced? If so what would be the best place to find these parts. If anyone has a better idea that i should do on the bottom end please lemme here your opinion.
Old Sep 9, 2003 | 01:54 AM
Got-LT1's Avatar
Can't help with the question on balancing (I THINK you always have to have it balanced), but if you use the stock size crank and pistons and connecting rods, I don't see why you would need to bore the cylinders out.
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
