Whats involved in a DIS ignition using LS1 coil packs???
Whats involved in using LS1 coil packs for coil per cylinder ignition???
If I can get the coil packs off a wrecked LS1 what else do I need??? I know the optical section of the opti will be used as a crank position sensor. Now I imagine there is some sort of controller too right? I'm trying to figure out which setup will be cheaper for me, the coil pack per cylinder or the dynaspark. Thanks.
carguyshu
Jan 22, 2017 11:19 AM
