fan switch info (*different question)
Old Sep 10, 2003 | 07:04 PM
slow's Avatar
When doing a fan switch for the LT1 cars, do you need to run the 47 ohm resistor between the switch and the place where you tap into the harness.
Assuming you had a plug in harness, (like the slp one) would you be better with a diode between the pcm and the add on switch. Or just use the 47 ohm resistor.
I have various 98-02 Ls1 cars that i will be testing my new fan mod on, but no lt1's
All help is greatly appreciated.
Ryan.
Old Sep 10, 2003 | 07:49 PM
The 47 ohm resistors are for use on OBD-II cars to keep the pcm from throwing trouble codes because of the switch.
The diodes are only necessary if the LEDs don't work right.
cristian1311
Nov 23, 2014 02:22 PM
Rich_z28
Sep 13, 2002 03:35 PM
troywg
Sep 12, 2002 07:28 PM
Rich_z28
Sep 8, 2002 12:00 AM
sfGi8nt
Aug 1, 2002 05:54 AM
