Should I replace fuel filter?
Old Sep 9, 2003 | 10:35 AM
NewbieWar's Avatar
Well i just got my car, and i donno how things are really supposed to be running... and i just wanna make sure everything is in peak condition. Is there a difference in fuel filters? what kind should i get if u recomend i change the filter at all
Old Sep 9, 2003 | 10:50 AM
madwolf's Avatar
Of course, why not?
It's only like a $10 part and it takes 15-30 minutes at most to replace it.
You will need needlenose pliers for the back side of it (to disconnect the fuel line) and a couple of open end wrenches for the other side. (I usually use a bigger and a smaller adjustable wrench)
Remember to change it when the car is cold and don't forget to releive the gas tank fuel pressure by removing the gas cap.
As for what brand, I've always used AC Delco fuel filters, but it probably doesn't matter.
Got-LT1's Avatar
How many miles on the car? i would change it anyway, because when I changed mine, it was damn near black in there. The new one was nice and clean. I just got one at a pepboys.
Old Sep 9, 2003 | 11:10 AM
PatriotTA's Avatar
Yeah, definitely change it. You might want to do plugs and wires while you're at it. I like to do a tuneup when I buy a car, but that's just me. At least pull a plug and check the condition. As for the fuel filter, get a pan or something to catch the fuel that's inevitably going to spill out. Put it in your lawmower when you're done Also, if you can bleed some fuel pressure from your schraeder valve, its real easy if you have a fuel pressure gauge.
Old Sep 9, 2003 | 11:56 AM
IXLR894Z28's Avatar
$9.59 at advance auto parts and well worth it to change.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
